Posted by Janicholson on November 07, 2012 at 22:18:09 from (96.24.99.126):
In Reply to: Need Road Band Advice posted by Bob in Mi. on November 07, 2012 at 08:30:07:
The use of 1/2" material (medium carbon steel) is best. 3/8 will bend and dent. Support on tips of grousers is good, with no span exceeding 13 or so inches. If supports are to be placed between points, they should be of the same strength as the band. Placement on the inside of the steel allows better trailering, and (to me) better look. Tank production manufacturers are able to produce the loops for a nominal fee. Welding the splice should be at least 70,000psi rod, and full depth penetration. Ground flat, the weld disappears. Best of luck Jim
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
