Re: M and W 9speed cable
Posted by D Slater on November 08, 2012 at 05:11:04 from (184.15.8.142):
In Reply to: M and W 9speed cable posted by DC3puller on November 07, 2012 at 09:37:01:
Not the best way, but have used cables that are a little bigger wire and used a dremel tool to get it to fit the nut. Used a cutoff wheel and stone to do it. Slow work with trial and error though.
