Re: 706 Engine Identification
Posted by mazemeister on November 08, 2012 at 14:18:29 from (24.187.98.163):
In Reply to: 706 Engine Identification posted by John_B on November 08, 2012 at 12:43:00:
263 or 291 on the gasser, diesel were 282 or 310. there was a serial number break at some point when they switched to the larger engines.
S-Y suffix indicates you have a TA and 12 gpm hyd pump.
