Re: Farmall 200 clutch replacement
Posted by clint s on November 08, 2012 at 14:26:58 from (24.59.217.58):
In Reply to: Farmall 200 clutch replacement posted by Janicholson on November 07, 2012 at 16:24:24:
Going to replace everything including the seals before and after tranny as they are leaking. Throwout bearing is sticking bad and now sometimes it will not disengage the clutch, sometimes most of the way but not fully , that has worn the clutch
