Re: 706 Engine Identification
Posted by John_B on November 08, 2012 at 17:56:31 from (4.252.209.162):
In Reply to: Re: 706 Engine Identification posted by The tractor vet on November 08, 2012 at 15:52:20:
I found it...it is STAMPED in the block...it"s a 263. It does have TA so the letters make sense as well. Thanks for replies. Only numbers I havn"t found yet are on the carb. Maybe it had a brass tag under one of the bowl to body bolts that"s missing?
