Re: M Hydraulics
Posted by DeltaRed on November 09, 2012 at 07:35:56 from (67.6.219.50):
In Reply to: M Hydraulics posted by Sparky2 on November 09, 2012 at 05:52:05:
Kinda depends on the loader.For an older trip bucket/oneway lift cylinder-occational lightduty use,the tractor hydralics(belly pump) will be fine.If you're going for a larger HD loader(such as a F-11 Farmhand)with lots of heavy use,you will very definitly need a pto pump,something with 15-20 gpm..
