Re: MD Battery Cables
Posted by D Slater on November 09, 2012 at 17:46:10 from (184.15.8.142):
In Reply to: MD Battery Cables posted by hattrick on November 09, 2012 at 08:49:38:
On a MD there was no positive to ground wire from the under tank box. Wire from battery negative post to starter switch would be close to a gasoline tractor length or the same and also the ground wire. IH did have a different part # for a gas and diesel battery to starting switch wire. Suspect that may be more to do with wire size than length. I could measure some and get you close, but chances are the battery you use may have different post placement than the original battery or the one I would measure from.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
