Re: M Hydraulics
Posted by mkirsch on November 10, 2012 at 06:16:25 from (64.80.110.74):
In Reply to: M Hydraulics posted by Sparky2 on November 09, 2012 at 05:52:05:
Live hydraulics are big $$$. $900 for the live pump alone.
You don't want used. Used pumps were taken off for a reason, and these pumps can't be rebuilt. You're taking a real risk paying 1/2 new for a used pump and then finding out it's no good. Then you do it again, and you may as well got the new pump in the first place.
The PTO pump's only disadvantage is it's not "live" and will stop when you push the clutch pedal. If the pump came with the loader or you already have it, it's $900 you don't have to spend.
