Re: M Hydraulics
Posted by mkirsch on November 10, 2012 at 06:21:57 from (64.80.110.74):
In Reply to: M Hydraulics posted by Sparky2 on November 09, 2012 at 05:52:05:
Wardner is suggesting that you fill the differential housing and transmission with HyTran, and use it as a reservoir.
It's kind of a radical idea. These old tractors use heavy gear lube in the transmission and there are a lot of people who believe that if you don't use the "exact right oil" for something, that it will turn into dust and blow away in the wind.
Hytran will work fine in the M's transmission, but it will be noisier when you drive. The heavy gear lube does serve to deaden the gear noise some.
You definitely want to get the transmission and differential housings CLEAN AS A WHISTLE to start with, and put the biggest hydraulic filter you can find on the suction, if you go this route.
