Posted by pete 23 on November 10, 2012 at 09:46:45 from (74.32.238.2):
In Reply to: 886 360cid inj.pump posted by Icuby on November 09, 2012 at 19:26:59:
Leaking around the head of pump usually requires the housing be replaced as they get a groove worn in them and then a new o-ring will not seal. You would need pump completely gone through.
To remove pump, remove the side cover, four screws, turn engine until mark comes around on gear, then turn a little more until timing mark lines on hub up with pointer which is under front pump cover. That will be about 18 degrees before tdc on front pulley.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
