Re: M Hydraulics
Posted by Sparky2 on November 10, 2012 at 11:37:43 from (50.40.127.249):
In Reply to: Re: M Hydraulics posted by IH fan on November 10, 2012 at 09:58:22:
Well thank you very much. I assume I need to dismantle the distributor from the front engine mount and measure that bolt pattern and the pump will fit inbetween..sound correct? I'll see what happens when I call them Monday
