Look for the parts diagram in caseih.com on line parts catalog. The valve is in the cast iron block between the lever and the reservoir. The issue is that the valve is probably cycling due to contaminated fluid, and partially plugged up screen in the block. Put 300 in the first box. then select hydraulic system, then touch control, then hydraulic system flow control valve... near the bottom of that list. Jim
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
