Posted by IH fan on November 10, 2012 at 12:23:07 from (108.246.55.35):
In Reply to: M Hydraulics posted by FlipRutledge on November 09, 2012 at 05:52:05:
Sparky2 said: (quoted from post at 14:37:43 11/10/12) Well thank you very much. I assume I need to dismantle the distributor from the front engine mount and measure that bolt pattern and the pump will fit inbetween..sound correct? I'll see what happens when I call them Monday
I mis-understood when you said you "have the front plate" to mount a pump. I thought you meant a mounting plate to drive off the front of the crankshaft, not off the timing gear... this is what I have on my 240U, an added mounting in front of the grill.
To drive off the timeing gear, you will need a pump from a late SM or newer model, 400, 450, etc. I don't know if Northern has such a thing, I doubt it, but they might. Then you will need the gears off a newer model because what is on an M is not strong enough to stand up to the added load. Someone else can probably help you more here than i can as to part #s, etc.
I believe Wardner has belt driven off the crankshaft on some of his "concoccsions"... maybe he can post anothe rpictureof his set-ups.
This post was edited by IH fan at 12:26:33 11/10/12.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
