Re: Farmall H Carb Leaks - Video
Posted by GordoSD on November 10, 2012 at 17:10:54 from (64.33.250.162):
In Reply to: Farmall H Carb Leaks - Video posted by dstates on November 10, 2012 at 16:01:31:
You left the fuel on at the sediment bowl, your floatdid not seat the needle valve and youe air intake hose is full of gas. First thing, Close bowl valve. then pull that rubber hose and drain the gas out. The fix the float/needle vale problem.
Today's Featured Article - Maintaining Rubber Tires - by Staff. The broad use of rubber tires on farm tractors and machinery has resulted in a great saving in both time and operating costs since the time of steel wheels. There are, however, certain basic fundamentals in the care of tires that should be followed carefully if the owner is to derive maximum benefit from his or her investment. First and most important is to maintain proper pressure for the work at hand. Your best guide to proper inflation is the operator's manual or instruction book tha ... [Read Article]
