Posted by IH fan on November 10, 2012 at 17:41:58 from (108.246.55.35):
In Reply to: M Hydraulics posted by mkirsch on November 09, 2012 at 05:52:05:
No, I don't. However, mine is a part of the loader frame that wraps around the front of the tractor. I don't recall for sure, but doesn't the M crank come out the front at a slight angle? it may not work to do it the way mine is because mine comes straight out the front from the center of the engine crankshaft.
Maybe someone with a more intimate knowledge of the M can chime in about how a pump could be crankshaft driven on them. Belt may be your only choice other than a late SM, 400, 450 pump set-up. There are flex couplings that will handle a slight angle drive, but I do not know how much of an angle they handle or how much of an angle the M crank is.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
