Re: IH Windbreaker Question
Posted by Janicholson on November 11, 2012 at 16:56:22 from (96.24.99.126):
In Reply to: IH Windbreaker Question posted by MFan on November 11, 2012 at 15:27:54:
Almost all canvas type systems can be customized to fit. Cut as needed and pin together with "T" pins. Join with urethane door and window sealer and let set for 24 hours. Brackets and hardware are usually adaptable to be sturdy. Make attachments rigid so that the components do not flop around. Also make sure the canvas does not get tangled or intrud into the pedals. Canvas used under the tractor to "close the bottom is often very helpful in keeping you warm. Jim
