just put one on a C here this spring!! What you have to do is bake it in a pan of oil(i used vegy oil) I baked it at 450F four about four hours then when you put it on make shure you have the timing lined up and beat it home. I used a wood block and a sledge with smaller taps. I found that a hammer just would'nt do. The cam dose have some play back and forth that makes you think that you need to pull the cam, but you dont need to. They say that you need to bake it for a long time to evenly dispnse the heat?? It worked for me!!
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
