Re: block numbers.
Posted by RPM1941 on November 11, 2012 at 21:48:32 from (173.23.76.185):
In Reply to: block numbers. posted by farmall1234 on November 11, 2012 at 11:00:59:
Serial numbers are stamped on the block on original engines in each machine, it is located by the oil filter base on flat machined surface, should start with C then 221/263/282/301, then a longer number. Replacement engines are lettered in various ways.
