Re: Super C Camshaft Gear
Posted by Smith100 on November 12, 2012 at 06:28:44 from (199.192.211.205):
In Reply to: Super C Camshaft Gear posted by Smith1000 on November 11, 2012 at 10:39:18:
Thanks. Got the new one in the oven right now. It is about 25 degrees out this morning, so this is a good morning to put it on. Sounds like it can be tapped on. I read though that if it is hit too hard, the plug could pop out on the back of the cam. I'll get it good and hot.
