A 55 amp alternator will provide about 750 watts at full speed - ie. with the rotor spinning faster than about 3,000 RPM. However as the alternator heats up its output will drop off a bit. Also you must subract the 100+ watts "lost" inside the inverter (heat).
Bottom line is the BEST you might expect is about 600 watts continuous from your 55 amp alternator/inverter combination.
Now a 105 amp alternator (about 1,450 watts max) gets you closer. But you still have the inverter loss.
Also you need a way to spin the alternator at full RPM. To achieve this with the engine at idle requires significant (7:1 or 8:1) step-up from crankshaft RPM. Not a simple exercise!
As for fuel consumption at idle it should be easy to test. Simply rig a temporary gas supply (an old lawnmower tank will do) to the carburetor. Accurately measure a quart of gas and dump it in temporary tank. Now start the engine and note how long it takes to out of gas. A quick calculation will then tell how long you can expect from a full tank.
This post was edited by Bob M at 08:56:39 11/12/12.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
