Re: Super C Camshaft Gear
Posted by Smith1000 on November 12, 2012 at 09:19:39 from (199.192.211.205):
In Reply to: Super C Camshaft Gear posted by Smith1000 on November 11, 2012 at 10:39:18:
I had it in the oven for 35 minutes on 450. That part worked fine. It was plenty hot/expanded, but that shaft has give in it and, unless the gear was completely loose going on, it is not going to go on all the way because the shaft retreats. It also has to mesh with the crank gear, which puts pressure on things.
I might just be able to tap the center of the shaft and draw it down. That might be a better option than pulling the shaft.
The key had shifted and I didn't realize it. I think that is when it moved throwing the timing off. The other thing is I did not pull the hydraulic pump gear. I will pull the pump off for the next go around.
