Re: Super C Camshaft Gear
Posted by pete 23 on November 12, 2012 at 10:59:01 from (74.32.238.2):
In Reply to: Super C Camshaft Gear posted by Smith1000 on November 11, 2012 at 10:39:18:
About three things here to be concerned about.
First, if you have to tap it on you are putting some
force on the oil pump drive gear, second, if it goes
back far enough it will loosen the expansion plug
behind the cam so then you can split tractor to
replace it. Third, that engine has none or at most
one cam shaft bushing so pulling the cam out is
actually quite easy. No big worry about scratching
the bushings when pulling out and back in.
