Posted by El Toro on November 12, 2012 at 14:45:42 from (108.3.143.30):
In Reply to: Super C Camshaft Gear posted by Smith1000 on November 11, 2012 at 10:39:18:
I would do as Pete 23 suggested and pull the camshaft before you damage something. Drop the oil pan, oil pump, remove rockers, pushrods and push the tappets up into their bore. Then you can pull the cam. Have your local auto machine shop to press the new gear on. Separate each item you remove and mark where it was removed. Cardboard boxes are usually handy for this. Hal
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
