Re: 300 Utility hydraulic questions
Posted by Janicholson on November 12, 2012 at 15:00:03 from (96.24.99.126):
In Reply to: Re: 300 Utility hydraulic questions posted by 300 dave on November 12, 2012 at 06:16:20:
The drain is on the right front bottom corner. it allows oil to run down the side and under. (I put a short length of pipe nipple in the hole quickly so as to keep mess to reasonable levels). I believe the valve will need to be taken off. The reservoir does not One screen to clean is in the reservoir. Jim
