Posted by CNKS on November 12, 2012 at 17:05:13 from (63.233.133.242):
In Reply to: Painting thoughts? posted by KTNC on November 12, 2012 at 15:19:43:
I use PPG Omni base clear and have had no major problem. I do the sheet metal and the cast. For touching up the cast I have some single stage urethane that matches the base clear close enough. As to the gas tank don't try to paint it clear to the top of the opening. Leave the area covered by the gas cap unpainted. Or if you are afraid of rust cover it with epoxy primer along with the rest of the tank. If the correct police are reading this, yes it gives a brighter finish than single stage urethane -- I like it that way.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
