Put on all 3 coats 10-15 minutes apart, let it sit for a couple of days, then if you are not satisfied with the finish, sand it and apply another coat, otherwise color sand it and buff it out. I see no reason to sand between coats--basically that ended with the mostly demise of acrylic laquer. Urethane is far better. That is not necessarily only my opinion as to the time between coats, it is in the tech sheet for the paint.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
