Re: 1951 M Farmall Engine Block Problems
Posted by jakee on October 22, 2000 at 17:19:31 from (152.163.201.206):
In Reply to: 1951 M Farmall Engine Block Problems posted by Brent R on October 22, 2000 at 13:51:33:
most M blocks crack behind the dry sleeves. you can then bore out the bolck and set a new wall then fit the dry sleeve,if you find another block make sure ti has the right main cap,s on it.or you will have to line bore it.
Post A Followup
: Re: Re: 1951 M Farmall Engine Block Problems
