Re: Another cast welding question
Posted by D Slater on November 13, 2012 at 05:04:15 from (184.15.8.142):
In Reply to: Another cast welding question posted by BigTone on November 13, 2012 at 03:49:50:
Problem with just welding on the tractor is the oil in the pores of the cast iron. Hard enough to get clean with a bare housing. That said, there's a lot that are welded. Some okay. some seep, some leak. Some have a sealer added to the weld on the inside. Also some with sealer and a steel plate added on the outside with a lot of bolt holes drilled and tapped to attach it.
