Word to the wise here find a housing that is not pushed thru due to a bearing failure . If one bearing is bad then you can bet your donkey there are others just waiting to come unglude . Same thing happened to a friends S/MTA and it did A fine job on the rear end housing . We used a 400 housing and put his GOOD parts in it and replaced all the bearings and seal. Could i have welded it yes BUT in the welding it would have burnt off the paint inside and we could have had a seeper thru the cast housing , would it be as strong as one not welded no . Is it a big job yes, do you want to do it a gain , probably not.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
