Posted by mike1972chev on November 13, 2012 at 10:53:17 from (75.149.81.173):
In Reply to: Re: Painting thoughts? posted by mike1972chev on November 13, 2012 at 03:48:22:
Well,DONT "throw rocks"at me,but here is my Ford 600.It has ONLY the sheet metal base/clear coated. ALL of the cast is a GOOD quality single stage automotive grade paint.
I am glad i did it this way because I COULD NOT tell you how many times I hd to touch up a bolt head,cover,nut,brake pedal,ECT. Single stage is easier to do that to.And it looks nice on a cast surface.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
