Posted by Janicholson on November 13, 2012 at 17:16:15 from (96.24.99.126):
In Reply to: 806 TA posted by farmallzach on November 13, 2012 at 16:51:25:
Aim it at a clear stretch of field, put it in road gear, give it 3/4 throttle and let the clutch out rather rapidly (as though you were a novice with a stick shift Falcon). If it rapidly kills the engine, the clutch is probably OK. If it takes off and builds speed till it travels at the throttle setting, the clutch is toast. Jim
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
