Posted by Janicholson on November 13, 2012 at 17:24:05 from (96.24.99.126):
In Reply to: 560 with 301 posted by farmall560guy1234 on November 13, 2012 at 16:46:16:
Using a timing light hooked to the coil wire not #1 plug, aim the light at the front pulley. watch the pulley from Idle to full throttle, the pulley should appear steady at any speed, and rotate smoothly to the max. This is a way to look at the distributor cam bushing wear. If worn, it will be herky jerky and not steady. The irregularity (if present) should be no more than about 1/16" of movement. Rebuilding the distributor would be needed. If the pulley does not change position with speed the centrifugal advance needs to be repaired. Jim
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
