Re: Super C Camshaft Gear
Posted by Owen Aaland on November 13, 2012 at 23:55:38 from (216.47.35.197):
In Reply to: Super C Camshaft Gear posted by Smith1000 on November 11, 2012 at 10:39:18:
I had a tool made to install cam gears. You need an extra camshaft nut. Weld a 5/8 of 3/4 bolt to the nut being careful not to damage the threads. Use a lathe or carefully grind down the weld and nut until the gear will pass over the nut. Install your new tool on the camshaft and put the gear in the correct position. Use a piece of pipe or a bushing that will clear the tool and draw the gear on with a nut.
