Reason for different part numbers is capacity of the bearings were changed several times. Then they dropped the shield on outer axle bearings in 560 and lubed from final drive. Every time you see loading grooves in a bearing it means they added more balls and had to provide clearance to assemble them.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
