Re: moisture coming out of exhaust on startup
Posted by farmallday on November 15, 2012 at 06:14:09 from (184.21.113.230):
In Reply to: moisture coming out of exhaust on startup posted by PretendFarmer on November 15, 2012 at 06:07:50:
is it only on the start up that it was coming out??
If it continued after the engine is warmed it should
burn as white smoke in the exaust. Did you check
your water level?? If its low that might also tell
you something.
