Re: 806 TA
Posted by mkirsch on November 15, 2012 at 11:47:39 from (64.80.110.75):
In Reply to: 806 TA posted by farmallzach on November 13, 2012 at 16:51:25:
TA is basically a two-speed powershift.
It gives you an extra speed between each main gear.
IH never put TAs on tractors as small or old as the A, so you're not missing anything on your tractor.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
