Outter axle bearing ST 675 has 15 balls and is not shielded if you want the shielded type the following are some.
Don't know if anyone still makes them but a BCA-1214 was shielded with the same # of balls. PL-270-WP, ST-253 also 15 balls. There was some new departure heavy duty ones also.
Inner axle ball bearings, none shielded. ST-223 and ST 223-A. Some 15 and some 16 balls. L-270 15. ST-265 15 balls. L-265 16 balls. Other numbers were used also.
Also if I remember correct the ST 310 outer axle bearing was 11 balls and the ST-310-A was 10 balls.
This post was edited by D Slater at 16:59:19 11/15/12.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
