Char-Lynn
Posted by Notjustair on November 15, 2012 at 18:02:23 from (174.229.65.37):
This CANNOT be right.
Decided to see about o rings in the Char-Lynn steering motor on the new M. Previous owner had taken it off. He said there was something wrong with it but never eluded to the symptoms. I pulled off the "nose" end of the thing and there are no gaskets between the different "collars"? That can't be right. Has someone taken this apart before and taken the gaskets out? All I found were two O rings on one end and one o ring on the other end. There has got to be more sealing this thing up!
If someone else has been in it I may just buy a salvage one. I've heard about having them out of phase and I have no idea what someone else did. All of the insides looked just fine to me - no obvious signs of wear.
