Re: Farmall 300 Fast hitch cylinder removal
Posted by D Slater on November 15, 2012 at 19:09:56 from (184.15.8.142):
In Reply to: Farmall 300 Fast hitch cylinder removal posted by Dean Olson on November 15, 2012 at 18:19:35:
There is a roll pin through the cylinder shaft end eye and the pin. Roll pin comes out then the big pin. Lower pin should be easy to figure out or like the other poster said.
