Re: 1566 won't start, even with ether
Posted by Brownie 450 on November 16, 2012 at 03:35:33 from (66.43.241.198):
In Reply to: 1566 won't start, even with ether posted by dryden j on November 15, 2012 at 21:55:57:
Can you hear one or more cylinders being weak as the engine turns over? As in 1 or 2 cylinders not coming up to correct pressure? I'd be sure the fuel is good & is getting to the pump. Check for ice blockage in the fuel lines if you are below freezing. Are the filters clean & letting fuel through? Is the return line from the pump open/ no blockage?
Have you had the pump off--did it get put back in correct time??
