Re: Standard BLOCK Bore C113 and C123
Posted by gene bender on November 16, 2012 at 04:06:49 from (207.177.56.85):
In Reply to: Standard BLOCK Bore C113 and C123 posted by equeen on November 15, 2012 at 20:34:27:
You need the part # on the block as later blocks would accecpt 3 1/4 sleeves olser blocks were the same with the exception of having a place for the hy pump. You need to measure the bottom where the sleeve seats to see which block you have it will also have the place for the hy pump. Side note a 113 block will take larger sleeves making it 123cu in.
