Posted by gene bender on November 16, 2012 at 04:21:20 from (207.177.56.85):
In Reply to: head straight posted by tuckaway on November 15, 2012 at 16:05:17:
You put the headbolts in before putting the head on cause how are you going to tighten them if the head is on first there nothing but threads sticking above the head after the head is installed and putting a pipe wrench will destroy those threads so you install the headblots first.Make sure the threads in the block are clean and also the threads on the headbolts are clean. Use some lube when installing the headbolts.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
