Don't really know the best answer to that. When IH went to the unshielded bearings and no grease fittings hydraulic transmission oil was used with oil return to the transmission a little different than early models. Don't know if heavy gear oil tractors would make a difference or not. Then you find some with the shield unattached to the bearing at removal. Due to overgreasing or other. You can find unshielded bearings installed later along with axle caps with no grease fittings on M tractors on up. Shielded with the right amount of grease at the correct intervales may be extra insurance if the tractor is operated with one side high for long periods. For incorrect greasing the open is probably better. When the open bearing is installed with grease fitting axle caps, plug the fitting holes.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
