The probable reason the loader drops is beacause the cylinders that do the lifting have bad seals on their pistons. They are rebuildable. To check the seals put a jack under the bucket so that the jack is extended at least 8 inches. Lower the bucket to remove all pressure from hoses. Remove the pressure hose from the Liftall and (avoiding loss of fluid) cap it. If the hoses run from both sides, cap both hoses. Now lower the jack. If the loader drops as before, it is the seals in the cylinder. Local hydraulic shops fix them routinely. If it stays up, the Liftall controll is leaking. (much less likely) The return hoses are probably routed to a T at the fill pipe. If routed to the drain with a close nopple and T they will not squrit. Jim
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
