Re: Farmall 350 Utility, Loader won't go up or down, no power st
Posted by Janicholson on November 16, 2012 at 19:07:39 from (96.24.99.126):
In Reply to: Farmall 350 Utility, Loader won't go up or down, no power st posted by T.j lockhart on November 16, 2012 at 15:56:09:
I would first check the single or double acting controls on each hydraulic lever. These are on the end opposite the lever. they are a roll pin through a milled flat. the roll pin must be either in the D position for two way action or S for single acting cylinder control. If these have been bent, it the little tin guard over the pin is distorted, they will cause issues. Let us know what you find. Jim
