Re: Standard BLOCK Bore C113 and C123
Posted by CNKS on November 16, 2012 at 19:51:44 from (216.144.104.128):
In Reply to: Standard BLOCK Bore C113 and C123 posted by equeen on November 15, 2012 at 20:34:27:
The 898 block was initially sleeved with thicker sleeves to give only 113 cu in until the Super A1 and Super C appeared. Then the cu in went to 123. The 898 blocks in the 113 and 123 were identical and had identical bores, only the sleeves were different. The current engine kits have sleeves that allow 134 cu in without increasing the size of the original bore. The 898 block is not to be confused with the original C113 block, which will accept later sleeves no larger than those giving 123 cu in without boring.
