Posted by IH fan on November 17, 2012 at 15:11:13 from (108.246.49.177):
In Reply to: IH hydraulics posted by Al L. in Wisc. on November 17, 2012 at 11:25:31:
hayfarmer said: (quoted from post at 14:25:31 11/17/12) I am more familiar with JD hydraulics but I have a SMTA also. JD went to the closed center hydraulics with New Generation tractors(mostly). Did IH change to closed center also and with what series of tractor?
I can't answer your question as to when/if IH changed, but a closed center system requires a pump that will drop to at, or near a no flow condition, generally just enough to allow a low sensing pressure. Most use a pressure or pressure/flow compensated pump which cams the swash plate of a piston pump back to neutral. Then when a valve is opened in the system, the swash plate is rotated or cammed to an angle to increase the flow. In a presure comp, it generally cams to a set angle, or all the way to a stop... in a p/f comp pump, the angle will vary according to how much the valve is opned. If anyone knows what type of pump is in their tractor, it should tell you if it's an open or closed system.
This post was edited by IH fan at 15:12:28 11/17/12.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
