Re: Ammeter Suddenly Shows Charging
Posted by Bob M on November 17, 2012 at 17:13:40 from (69.207.86.27):
In Reply to: Re: Ammeter Suddenly Shows Charging posted by F4RM@11 on November 17, 2012 at 14:50:26:
Your generator was likely polarized backward; jumpering BAT and GEN terminals fixed that.
Could also however be an intermittant problem involving the regulator ground - especially if the regulator is in the stock location bolted on the front of the steering wheel stanchion. (The Super M is notorious for VR grounding problems here.)
Suggest running a #14 ground wire from the regulator base to a GOOD frame ground - ideally where the grounded battery cable is attached.
This post was edited by Bob M at 17:18:29 11/17/12.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
