Posted by Bob M on November 18, 2012 at 08:02:20 from (69.207.86.27):
In Reply to: just curious. posted by Tuckermac on November 18, 2012 at 07:37:23:
Like CNKS says, it depends what you grew up with. It was Farmall for me; I still much prefer them today.
Incidentally I still operate early 50's era Farmall, JD, Case and MM tractors on a regular basis. I find the green ones somewhat cumbersome - the ergonomics are just wrong for me. The Case and MM's are better. But only the Farmall's feel "right" to me.
However I have several "green" friends who feel the same about their 2 cylinder tractors. Both Farmall and JD's have advantages and disavantages. Also all perform as their designers intended. So it really boils down to personal preference.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
