Re: Cam gear
Posted by D Slater on November 18, 2012 at 08:13:18 from (184.15.8.142):
In Reply to: Cam gear posted by BudKaiser on November 18, 2012 at 07:00:10:
450 tractors came with the best cam gear IH made. 450 tractors engine serial number 9860 and lower used a cam with right hand threads and 9861 and higher used left hand threads without a lock plate to help with the nut comming loose problem. Left hand thread cam and the late cam gear is all thats sold for years now. Unless someone has a new old stock laying around. Aftermarket parts should be patterned after the later IH replacement parts.
Can't remember the specs on cam end play without looking it up.
Today's Featured Article - Talk of the Town: Repairin a Gas Tank - by Staff. This interesting discussion is from the Tool Talk Discussion Forum. Remember that safety is your first priority - make sure you know what you are doing before attempting a potentially dangerous activity! ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
